Any help with this would be very much appreciated!!
We are having a problem with the wiring on a BHC-3 502. Whenever we turn the to the on position (without starting the bike) the fuse for the Brake and Horn blows. We have disconnected the entire lighting of the backend, and tried it again, the same thing happened. When we pull the wire from the clip on the fuse block and put in a new fuse, turn the key and it is fine, but as soon as we plug in the connection to the fusebox for that circuit ( the 6 wire and the 15 wire combined into one) the fuse pops.
We have unsuccessfully tracked down the #6 wire (Hot to Horn) to see if that is shorting out.
So any help would be greatly appreciated....!!!
