against the wall with legs spread!! Oh sorry, I got confused..
You put a jack stand under the frame on the right side near the foot peg while the bike is over on the kick stand. then you get a floor jack under the left side and carefully jack it up and put another jack stand under the left side. the bike front wheel should now be off the ground. You put the floor jack under the tranny x-brace in the rear and jack up the rear then put jack stands under the rear on both sides. I put a piece of 2 x 4 onder the cross brace before jacking it also. Just go slow and take you time, be safe.
This is the way I jack the Boss up.
You can use channel locks or vise grips to loose the spanner bolts, again be careful they have o-rings under them so don't over tighten. You can also use a set of needle nose pliers spread and put the ends in the two small spanner holes.
FastEddie
