Hi guys,
I've got a strange sqeal in my bike. The alt belt was loose and that went away after tightening but there's something else.
Once in a while it almost seems like a rumbling bearing noise coming from the transmission at an idle. And then it may be a slight squeal or go away all together. When I first take off, it seems the transmission squeals pretty good under load until I get to 20mph or so. I'm inclined not to give it too much because it doesn't sound normal. After that the trans operates normally.
I've checked the oil and it's in the sightglass. I'm going to drain it and change it soon anyway, but was wondering about any suggestions you may have. I'm suspecting the torque converter but hope there's no problem. It's an 2003 2 speed.
thanks
thanks
