1 - 2 of 2 Posts
My recessed license plate is mounted from back side of fender and I can't get to the nuts between tire and fender to change new license plate. After removing shocks and brake rod, how far will the tire and swingarm drop down without having to loosen the belt? I need enough clearance between tire and fender to get my hand and wrench in to change tag. It is bad to have new personalized tag and can't install it!
Boyd , If you disconnect the shocks and the brake rod , it should drop far enough for you to get your hand in there to remove the plate .
1 - 2 of 2 Posts
