1 - 2 of 2 Posts
I could use some advise on carbs. I want to go to a 750 with mechanical secondaries on my small block. A new intake manifold will sit about 3/8 of an inch higher. I read the previous posts about the Demon and have pretty much decided to stick with a Holly. My questions are: Will a 750 be wider and have a problem fitting between tha frame rails? Which model # 750 should I look for? Which brand of fuel pump, Carter or Holly will fit in the space provided?
Regards,
Kurt
Discussion Starter · #2 ·
Duh,
I somehow got it in my head that the 350's were running 650 carbs, must have been some GM literature. Levi at BH set me straight about the Edlebrock 750 installed at the factory. I could still use advise on a good mechanical 750 and a fuel pump.
Thanks.................
1 - 2 of 2 Posts
