well I recived my rebuilt kit from NESCO to day. I machine out the two grooves in the front cover and press in the bushing, Then polish the shaft and cut a groove to replace the spiral clip with a C clip on the clutch end ..
they didn't send the bushing for the clutch cover but JIM at nesco send one out to day. my trans had the up date on the pully cover (if a B is after the # on the trans you got the biger bearing in the pulley cover).. so tomower it will go back together.. that mobil 1 MXT4 10w-40 I pick up today put me in sticker shock...$7.00 per QT .. Is there any thing I should do to get at lease 10k mile this time? all help is needed thanks M. J.
