Oldman,
I believe that you are seeing brown (John Deere) and red (Dextron). The idea is to get most of the fluid out when changing from Dextron to the John Deere. Easiest way:
-Pull plug on pan drain.
-Replace in-line tranny filter.(don not connect the "suction side)
-Take short piece of tranny line and connect one end to "suction" side of filter and put the other end in the jug of John Deere Hyguard.
-Start bike and with front brake locked hit your switch on as if you are going to drive. (do this a few times.)
-Allow the rest to drain out of tranny pan again.
-Rehook your suction line to tranny tank.
Put plug in and fill as needed. This should flush your system enough.
