I am working on a 02 Boss Hoss for a friend. He bought new wheels, matching pulley and disc from Marv at the Rally and it has a wobble at 115 to 120 mph. It also needs to have the hub chrome so here is where I am at. First I checked the belt tension and it was right on. The belt was dead center so I wanted to try the laser light deal like we do on our trikes. I used a laser level to butt up to the rear wheel and a ruler at the front wheel. I found that the wheel was cocked 3/4 of an inch to one side. I will worry about that when I get the hub back and mount the new tire. I had to remove the rear races so I could get it to the chrome shop and this turned out to be a bit of a problem. I cut two pieces of flat steel 2"X1"X1/4 and welded them to the races. Then turned the hub over and knocked them out. Worked like a charm so thought I would pass this on.
Will let you know how it goes when I get the hub back and do the alignment.
