It is hard to believe, but I actually have a question about overheating in stopped traffic. This last weekend it was in the high 70's, may have actually been 80. It just lasted one day and then it got cooler and rainy again. I am running my carbs lean and the thermostat at 180 so I can try to increase my mpg a little for a big upcoming run. I will share more on that later.
I actually got into a traffic jam. Imagine that in Houston. I was stopped for probably 15 mins or so. The temp ran up around 200 degrees. I finally passed the traffic jam, and it started cooling right off. I got up on a big bridge where the air was blowing nicely off the water (cool), and looked down and the temp was rising. It actually did this thing where it slowly went up to 200 d and then back down to slightly below 180 (where it normally stays). It did not seem to be related to engine speed. I have a condensate recovery system and it has been working well, I think. Could this be some indication that maybe my water pump is acting up. The radiator was cleaned out :capwin: last fall. I will check my levels before I take off again to make sure that they are topped off, but she seems to find a level where she likes to stay and then works great, as long as there isn't a traffic jamb. I even let the water pump run for a couple of minutes after shutting her down to cool her down below 160 to 150. I seem to remember a similiar deal like this last year in the spring. Any ideas.
Regards,
Crazy Bill "Critter" Crittenden
Seabrook, Texas
Regards,
Seabrook, Texas
