Re: Odyssey Battery questions?
hossman said:
Those of you using the 680, are they performing to your satisfaction? If I switch to a 680 will I have enough room leftover to install an alarm in there? I am trying to figure out a place to put the alarm where it won't be obvious or easy to get at.
Hoss
Hossie, you are able to install at least 2 alarm systems under
your seat if you buy the PC680. I've got a lot of tools under my ass, and I
think an alarm system would still fit. Sure- the 925 gives a little more reserve, but the 680 is enough- believe me. The engine cranks like hell, and even if someone twisted the throttle without you noticing, and the carb is flooded - happened a couple of times to me- no problem to crank the engine again, and again, and again, and again.
Buy it, you will be satisfied....guaranteed!
...just like a Walmart customer...hehehe...
