1 - 9 of 9 Posts
Just rapped up the install of my new Arnott air suspension system (Part #9024) on my 2012 Gangsta.
Went relatively smooth. The only thing that needed to be done was to drill new holes on the support bracket for the air compressor
so it sat closer to the frame, everything else was plug-n-play. Also picked up a nice switch that I mounted
on the bars between the grip and the controls all wiring is internal. I got approximately 3 1/2 inches of travel.
http://www.arnottairsuspension.com/products/productDetails.asp?groupId=158 (they don't have the Gangsta listed for fitment)
Electronic engineering Electrical wiring Computer hardware Cable Gas
Electrical wiring Gas Motor vehicle Automotive tire Automotive lighting
Really nice setup, came in box as you see it.
Sleeve Gadget Font Electronic device Netbook
Office equipment Gadget Gas Bumper Telephone
As you could see it didn't have to go over much to clear the body.
Gas Drinkware Cylinder Audio equipment Glass bottle
Automotive fuel system Motor vehicle Car Automotive design Vehicle
New compared to old.
Automotive tire Motor vehicle Vehicle Automotive exterior Rim
Motor vehicle Vehicle Gas Auto part Engineering
Unit hanging from frame rail.
Motor vehicle Automotive design Automotive lighting Automotive exterior Automotive tire
After all the wiring and plumbing was done I installed the switch.
I also added a pressure gauge from Dekota Digital.
Didn't get a chance to ride it yet, temp here in NY NY is in single digits.
Nicely done. I suspect you will be very favorably impressed when you're able to take that first ride. Here's hoping the winter is short and the roads are clean quickly!!
Mikie, looks good and clean. Did the
up and down switch come with the kit
or is a Pingle item???
Paul H
That is a first class job. I installed a set of Morrows on a couple of bikes and they are junk so trying to save a buck was a waste of time plus about $150. The compressor is a super one but the rest was just a drill.
Nice install...looks great...ride report is anxiously awaited.
Did you loose the auto ride height then??
Yes, I had to eliminate the self leveling option which can be compensated by on-the-fly adjustment.
...still waiting
... to ride it that is. Another 8 in. of frig'n snow yesterday.
Tire Wheel Automotive side marker light Car Window
1 - 9 of 9 Posts
