Need help on tranny return spring
1812 Views 6 Replies 5 Participants Last post by  SBarrV8
2001 2 speed-
My shift lever works but the trans. shifter return spring has either broken or come loose. I constantly have to pull the shift lever back 1/4 inch before I can shift into a different gear. If I hit a bump it may cause it to jump out. Really a problem if you are going from reverse to forward.
As I recall this is inside the trans. Can I get to it without splitting the frame (i.e. can I get to it by dropping the trans. pan only? Parts needed other than spring and maybe tranny gasket?
Thanks much.
1 - 7 of 7 Posts
You can change the spring by just dropping the pan. You have to replace the shaft as the spring and shaftcome assembled.
KAVEMAN
shift shaft change
SbarrV8;
This link is from WAGS help site on this forum, under V8 Links and Resources, and was authored by Eastern Mike.
Hope this is helpful.
http://webpages.charter.net/wag1/Shifte ... tnMike.txt
See less See more
Thanks
Kaveman, thanks much and Hawk-exactly what I needed.
It really is simple to change out the spring assembly, it just seems sort of intimidating at first...let us know if you need any help... :)
Steve,
How did you make out with the return spring fix????
Boss Man
GREAT instruction set from WAG on the tranny shifter return spring. Will do this weekend or next, also need to hook up vac. gauge and fuel gauge. Hey, it was time to change the tranny fluid anyway.
Thanks for the tips, saves me a 4 hr. 1 way drive to nearest dealer in Va.
1 - 7 of 7 Posts
