I told you guys that I was having troubles with cold starting recently and how the Boss would fire up and then die out while in high idle then maybe fire up again and die and then it wouldn't start for a while.
The fuel pump is dead.
I am in the process of rewiring my front end and after testing everything the only part not working is the fuel pump. I checked the ground and re-grounded it elsewhere. I have power all the way to the unit, unless the hard wire coming out of it is bad.
I am looking at a new fuel pump and I know that we talked about this over on the Yahoo site last year sometime and I remember something about fuel pressure being around 6 or 7 lbs. I found a Holley Red pump for about 95 in Jeggs and a Marine grade pump for 115. I also found a Carter pump for about $60. Are either of these OK? Or do you recommend something else?
Hoss
Hoss
