...and Horizontal. :biker:DC Reverse polarity sucks the weld into the joint of the two metals, AC streight polarity is a surface weld. It Takes hours not minuites to learn to weld. There are three differant positions: Flat, Vertical & Overhead. Overhead is the hardest. If you have never welded, you can't do it. and have it not fail, period!!! If you hate your Trike then do it yourself.John
Hi,
No arguement here, except yes, we do use a flux core with gas for certain welding procedures, but it's not the same core as gasless wire. Also, we never use straight argon on ferrous welds. It tends to not penetrate as well. We use various mixtures of CO2, Nitrogen and Argon combined. I think our most common is called 75/25 CO2/Nitrogen.
Argon is good for Tigging aluminum and other types of metal.
And no, I am not a certified welder. I just have a few thousand hours running beads and fabbing under my belt. I am a certified electrician who worked at an open pit mine and spent many nights in the welding shop when there were no machines down in the pit just to stay busy. I love working with metal.
That is way cool that you did such a monumental landmark.
I REALLY appreciate your support. Yes, like everything I try for the first time, I read up on it, watched a few YouTube videos and asked for ideas such as I did right here. Not too much I haven't been able to do mostly because of my stubbornness. I have been working on cars ever since I had my first 56 Chevy at age 16 (that's 40 years ago). I totally disassembled that little small-block V8 265cu. in. engine, honed the cylinders, put in new rings, valve guides, main bearings etc, put it back together and it ran great.Sounds as if you have read quite a bit in an effort to be prepared. Metal is relatively cheap so go get a few pieces of scrap metal the same thicknesses as what you will be welding on your trike. Glove up and suit up and put your mask to a setting of 10 so you can see clearly without damaging your eyes. Having those little Gnomes scratching the back of your eyeballs at night sux! so be sure to have the mask on before you even grab the stinger.
Place the two pieces of metal together and plan to weld the seam from left to right. Ground clamp on, Mask on, stinger in place (37.5 degree angle tilted top toward the right) ... pull the trigger. Hold the trigger for just a second or two until you see a small molten metal puddle form then slowly make counter clockwise circles about a 1/2" in diameter centered on the joint. what you want to do is spot the black dot in the middle of the molten metal puddle and slowly move your hand holding the stinger to the right while continuing to make 1/2" counter clockwise at such a speed that the dot stays 1/4" to 3/8" behind the weld.
When welding, the crackling sound the welding makes should strongly resemble eggs frying in bacon grease ( my cardio doc LOVES ME! )
Once you master flat welding you can set something up above your head and practice there. to check and see if your welds are properly penetrating the steel ... after you weld the practice pieces, turn them over and look for a discolored blue line where you welded. If quick enough, you can stop and turn the metal over mid weld and see the RED area. If you don't see obvious markings and metal heat evidence, turn up the heat setting.
Welding isn't rocket science ( actually it WAS! ) but you know what i mean ... take a little time to learn the craft and you will be fine. If you doubt your skills, take your practice pieces to a weld fab shop and show them your work and ask their opinion. If nothing else, it may open the door to meeting a metal fab guy that will help you out.
I like them words! My friend just told me that flux-core arc (FCAW) welding is about as easy as it gets with good metal penetration on metal 1/8" and up. He also says "Burn in the walls and the center will take care of itself." If the puddle flows and the weld washes in then the weld should be strong."Don't be scared boys.... your not monkeys playing with a hand grenade." :biggrin:
You have done well my son so keep up the good work.I Got er done this weekend. After practicing running beads and t-joints on Saturday like everyone recommended, my friend who has been a union welder for 26 years (including nuclear) did the bottom three sides for me. After he left I bolted Adrian's hinges on and raised the body up to get access to the top of the frame to finish welding the top.
Adrian's kit worked perfectly for me, and as of Monday night the gas lifts were installed and I was watching Monday Night Football.
Thanks to all the guys who encouraged me as well as the ones who said don't try it, because you all motivated me in different ways to complete my welding project. I have been working on cars since I was 15 when my dad bought me a 55 Chevy, I just never welded for some reason until now.
Like many said, I learned that welding isn't easy, it takes a steady hand, some strong neck muscles, and some fundamental knowledge of how gravity, gun work angle, gun travel angle, travel speed, and direction (push/pull) do matter. I was surprised to see how low my buddy set the voltage on the welder. The chart inside the unit recommended a "4" (the highest setting) on the voltage and a wire feed speed of "30." After running a few test beads, he turned the voltage down to "2" and did an amazing job. When I asked him why, he said "it was too hot," and he preferred to slow down his travel speed and the bead was still great with penetration.
I ended up using the machine set for DCEN-DC "electrode negative" = DCSP=DC straight polarity where about 2/3 of the heat flows to the metal being welded.
Also need to do a major shout-out to Adrian who I probably called 5 or 6 times about various things I needed his advice on. A very nice guy!
Here is a video of my wife lifting the body when the kit was installed.
Link to Youtube video of me welding the top of the frame: http://www.youtube.com/watch?v=eQf6WsByQwA
Link to V8 forum photo album of all photos of this project: http://www.v8bikeriders.com/forums/album.php?albumid=1359
1716
Sorry for the thread hijack but great to hear,Ric.I'm in the process of 'stretching' a Boss Hoss gas tank, but won't fit it up until I get my bike back from Destination Cycle, as it's having a Kewl Metal front end installed. Typically, I'd do THAT sort of work myself, but Barry and I have a plan. My reason for waiting until the front end is on... is so I can work with what restrictions the different angles may have in just how much I can stretch the tank. Once done, I'll practice the 'pretty' welding on scraps first, then dive right in and fabricate then weld in the extensions on the Tank Stretch project. I'll take pics as well, as I go along.
