Where do you add oil to the engine on a 502? Someone told me that on the valve covers is what looks like PCV valves....just pull one (doesn't matter which one) out and add oil. The problem is that the gas tank is sitting dead on top of these parts and the only way to pull them out is to remove/loosen the gas tank. The only other place that I can find is down the dip stick tube.
Really....there has to be a way to add oil to the engine without pulling the gas tank...right?
