1 - 5 of 5 Posts
Two month ago after I washed my bike, I took it out for a small ride thru our small town of Bückeburg. I realized that my left turn signal was flashing, and thought I forgot to shut it off. I pushed the turn signal button, and it was off -> for only 5 seconds!
Then it flashed again...and again...and again..... :evil:
I had to ride 4 hours around the same block! Hehehehe.....no, no...
I had to ride home, take the turn signal switch apart, and dry it with a hair dryer. After I did that everything was fine again. It was my mistake, cause I took a lot of water to wash all the bugs and flys from the handlebar lever and switches (should have to know it better).
A couple of days ago V8Andy called me and he said he's been on a bike meeting with his 2000 502 in Rüdesheim. On his way back to Cologne he was catched by a hard rain on the Autobahn when his left turn signal came on, and he wasn't able to shut it off - like happend to me two month ago. This self activating turn signal can lead you in a very dangerous situation.
My question is - is that "poor quality" problem of the handle bar switches fixed at the new bikes? I would like to have something better water sealed, and would buy new switches if availble.
Ghost Turn Signals
Loaf,
These are standard handle bar switches used on many, many bikes.
Do you have Radio Shacks in Germany? They have a product in a small aerosal can called "contact cleaner". It comes with a spray tube (like WD-40). Isert the small tube into your switch and give a short squirt. It is a lubricant, cleaner and leaves a water dispersing film on the parts. You should also use it on all of your fuse contacts. It keeps the contacts clean and provides a good connection as well as preventing corrosion.
Hi Neil,
yes, I do use such a product. It's a Battery contact spray from Liquy Moly (sp?). I use to spray it inside the handlebar switches from time to time. I do also use a battery contact dielectric grease (from Liquy Moly, too) for all the other good reachable contacts, connections and the fuses. Therefore
I can't understand how this can happen :(
Do you know a good source for high quality "direct replacement" handlebar controls for our Boss Hoss bikes?
I carry a small can of silicone spray with me on long trips. Whenever I hit rain I blast the inards with the spray and no problem. Also, when washing the bike, put either Saran Wrap over the modules or a baggie and the inards won't get wet. One time after a heavy rain my starter kept engaging with the motor running...not a nice sound. A blast of silicone spray into the keyhole straightened that problem out as well. I know of no waterproof switches
1 - 5 of 5 Posts
