I think this is my turn for a silly question....
How do you change/pull your front wheel?
The first time when I pulled my front wheel for changing the
bearings, I noticed that I have to remove the calipers first.
To be able to remove the calipers I had to push the pads
nearly all the way into the calipers.
A couple of days ago I had to remove the front wheel again
for changing the tire (Michelin Commander) and I remembered
a posting from Adrian a while ago. He said don't push the pads in,
cause you'll push the brake fluid back into your master cylinder
and you might destroy it - or open your bleed valves before to
avoid this.
I thought about an easier way to remove the calipers without
opening the bleed valves, and found out that it's very easy to
remove the calipers if I pull the brake pad springs 1/3 way out,
just enough to remove the inner pad on both calipers.
Is it really necessary to remove the calipers, or is there another, easier way to pull the front wheel?
avoid this.
