Lamont,
No problem...ring any time. If you miss me, just leave a message and I'll get back to you.
The early style FLH fairings like mine I think were used from 1966-1984, so they can be found fairly easy and relatively cheap. They were also fiberglass, so easier to modify or repair than the later versions. The later fairings are plastic (ABS, I think) and have the inner dash/console. The early versions are easier to fit, but you don't have the option of a radio.
My fairing uses modified Harley brackets and homemade adapters that bolt onto four of the short Boss Hoss windshield fork clamps. I can remove and reinstall in less than 5 minutes.
The aftermarket versions are good units and if I had wanted a radio I probably would have used one of those instead of trying to modify the dash on a later model FLH piece.
