You will get the best results if you set the total advanced at 36 degrees. If the engine is idling a little fast the distributor will be already advancing and give you a bum reading. Slow timing will cause a flat spot.Lonestar Rider said:
You will get the best results if you set the total advanced at 36 degrees. If the engine is idling a little fast the distributor will be already advancing and give you a bum reading. Slow timing will cause a flat spot.Lonestar Rider said:I have a stock 2002 ZZ4 350/385HP. I checked the timing per the manual and found it was advanced beyond the 10 degree mark. I reset to the 10 degree mark and it seems to have a flat spot at low rpm that didn't use to be there. Is everyone running 10 degree above TDC or is there a better spot for lowend torque?
Phil,AcroPhil said:I do not have the progressive computer, it justs come on 100% at full throttle after arming. Is this a problem?
Hi TimGRUMPY said:Phil,
I would think not, I really added the controller 'cause I want ed be able to control the wheel spin a bit..........I actually wanted to beat somebody![]()
Lots of guys running your combination and are very happy :lol: ]
The converters make a ton of difference and really make the bike feel strong.
I have done 5 Boss Hoss's and I tried it both ways. It works best for me by leaving the limiter out.Lonestar Rider said:Hey guys, I just received my kit from Summit. Think I can install per the instructions in the article on wags site. Is everyone using the limiter plate that comes with the kit or not.
