I switched to a Centerforce II clutch. After screwing up the part numbers on the first order, I finally came up with the right parts. These have been installed and found to work well.
Centerforce II Clutch for the Boss Hoss
Clutch Disc: PN: 383271
Pressure plate: CF361874
Throwout Bearing: N1086 (also a Centerforce part).
If you desire to install the Centerforce III (dual friction), their tech support could give you the corresponding part numbers for that clutch. Also, if you don't have one, get an $8 GM 10-spline clutch alignment tool with your order because they don't come with the clutch kit.
