1 - 20 of 38 Posts
Joe , for some reason I can't see it .
Thanks Joe and Don, that's the same can I have .
Lamont , I bought my Boss new from the guy that developed this particular catch can and it was Installed on the bike when I bought it . No it does nothing for cooling but does your bike ever puke antifreeze out onto the ground ? I don't know because I've never been without the catch can .
As you know I have used that ugly water bottle for a reservoir for a bit. It completely fills when the bike is hot, and completely empties when cold. That's what it does. Keeps the radiator full.
That's why I was asking about the radiator pukeing antifreeze . I know a few of my friends that wouldn't like an antifreeze puddle on their driveways when I come to visit them . I"d have to park it out in the road . It would be nice to have a catch can with a sight glass in the side of it so you could see what happening inside .
Overflow can
Stu;
If you could do a "Ripple" or "Chianti" there might be a good market! I'd certainly line up!
Lamont;
My Boss never stopped "spitting" until I put an overflow container on it (1 of Barry's). I kept hoping it would seek a level, but it didn't. When I would first turn the key on you could hear all sorts of gurgling in the cooling system. Spit can stopped that.
My radiator is about 1 7/8"s thick, and single speed kept the engine wound tight on the big road.
Mine puked until it got to a certain level and then it quit. I was going to buy one when I first went to Daytona on the Boss and a dealer talked me out of it. I guess it really doesn't matter. I did have one for a little while but have seen no ill affect by getting rid of it and it held a lot more than those little cans. :roll:
I've seen this catch can at the European Bike Week last year.
Mine puked not very much, but again, and again, and again, and again...
..until the radiator was only 2/3 full. After I installed the catch can it never
puked a drop after, and the radiator is full like I am at saturday night 2am.
Hehehehehehe...
Olaf , I like that idea with the sight tube or glass but I like the overflow can that Lamont made better because it is out of sight under the side cover and you can see thru it . My problem is I'm out of room under my seat and side covers but I'll have to think about this . I'm used to seeing the one I have but would rather it wasn't there . I like the clean look .
Thanks for upsizing the photo, Don.
My radiator continued to puke at every stop and a lot! Like Loaf, I actually had to keep adding coolant and it never found it's own level which I believed it would. It made no difference in terms of temp and cooling but I hated the mess after every ride especially on my garage floor. This little catch can stopped it totally and the puked coolant is then sucked back into the radiator as cooling occurs.
If you don't have the problem don't use one but if you do the small one works perfectly without the need for the really long unit I see posted. The volume of coolant puked is never enough to overflow the can...Joe
Lamont , what is that container , a widsheild washer tank ? Does it have a hose connector both top and bottom or did you have to fabricate ?
Doing a little testing here and I may have to eat a little crow. :roll: Seems I was lower than I thought as far a coolent goes and the new bottle seems to be helping as far as keeping the temps down.
You can get these at just about any auto parts store Jack.
Thanks Lamont , I'll check it out . Like I said , I would rather have my catch can hidden than hanging out in the open on the crash bar . I just got to find a space .
This site continues to save me money and give me ideas that sometimes just don't come to me. Like Jack, I would rather have my catch can hidden and was just getting ready to purchase one of those polished catch cans for $45. While looking at LaMont's picture of his plastic container, I saw the ratchet strap for his Odyssey battery. Not rocket science but for some reason I just didn't think of that when installing my Odyssey battery. I used a couple of humongous plastic cable ties around the battery carrier to tie mine down which is fine until I want to remove it. I did put some strips of tacky weather stripping on the bottom of the tray to keep the battery from sliding around in the tray. Thanks guys.
Mike
1 - 20 of 38 Posts
