1 - 20 of 35 Posts
I'm thinking about installing a wilder cam in my ZZ4 this winter along with a timing gear set up . All though I've wrenched on dozens of Harleys over the years and have done some wrenching on cars and trucks , I have never replaced a cam. Where can I find some step by step instructions to remove and install a new cam in the small block ?
A few more questions , what cam should i use to give me the best sound and performance , should I also install a set of 1.6 roller rockers , and is the timing gear set up going to sound good or will the noise drive me nuts ? Any and all advise would be greatly appreciated .
Hey Jack,
If you go to Comp Cams site, they used to have a complete installation guide available on line.
1.6 is what the GM hot cam setup uses for rockers.
Gear drives can be ordered in different "volumes" from sources like Pete Jackson, etc......they sound just like a 671/871 blower...... :lol: 8)
Thanks Tim , I'll check it out . Your a motor head , what Cam, rocker set and timing gear set would you recommend for the best sound ? Performance is also important to me of course but I need that great sound .
Well, I'm pretty happy with the performance that these Comp Cams produce.....they are ground a little different than the GM 'Hot Cam' kits so they don't have as much 'lope' to them.....but a couple years ago when I talked to Comp they said they had developed the grind for the weight of the bike....???
If you listen to the small blocks with 'real' GM Hot Cams, they sound a lot meatier. Interesting that BH says the current Comp Cam in a small block develops 385hp.....GM advertises the "Hot Cam' ZZ4 at 394hp....but ours use 1.53 rocker instead of the 1.6 and the grind is a bit different.....I just don't think that you can tell the difference in 10 hp or so......now add a little 'juice' & your 'butt dyno' will tell you that something is different......
just ask Steve Hanson :lol:
If I was doing it from scratch, I would probably use the GM kit and a Pete Jackson "noisey" gear set........they'll hear you coming for sure :lol: 8)
My first blower on my Valkyrie had straight cut gears on it and after about 3000 miles I couldn't stand riding it. That wine will get to you after a while. :evil:
Tim ,
So your saying that the GM Hot cam will give me the lope that sounds meaty ? If so that's what I want . Is there a part # or is it just called ZZ4 HOT CAM . Does this Hot cam require the 1.6 rockers or can the stock ZZ4 rockers be used with it ?
Lamont ,
I hear you on the constant whine . It may not be for me either .
Does anyone on this board run the timing gear set ?
If I'm not mistaken, Adrian was running a real "Hot Cam" in his motor at the rally......it sounded considerably more lumpy than mine. Right Adrian?
Could have been those darned headers too.
The 1.6 rockers and springs aren't necessary, but they add to the overall performance and work well with the ZZ4..........they were designed specfically for it.
Hi Jack, I'm running a Comp Cam # 8-422-8. It is very close in Lift and Duration as the GM Hot Cam. The only difference is, it has a 110LSA, the Hot Cam is 112LSA. The 110 grind gives the engine more low end torque. The Hot Cam is ground to perform better in the higher RPM range. Both Cams sound great and do add to the preformance. You'll just need to put the power where you want it.
I'm also running the 1.6 Roller Rockers. And replaced the stock springs with a 130# set. This all worked well on the stock heads.
But a little pocket porting wouldn't hurt things either.
If I ever go to a gear timing set it will be the quietest ones.
Just my 2 cents
Discussion Starter · #11 ·
Thanks Tim , Wag and Mike for all the info . I know I can do this cam replacement with some instructions .
Do I need any special tools or pullers ? I've got all kinds of tools and a standard set of pullers but if I need anything special I'll order it before I start the project .
You won't need any special tools, except the steering wheel puller to pull the front snout. It is a straight up job. A quick way that I do it (and have done 4 in the Boss's) W/O pulling the engine. I take the bolts out of the pan in the front all the way and just loosen the back bunch (almost to the last couple of threads) so I can drop the front of the pan. You have to drop the pan to get the front cover off but you won't need to pull the pan off all the way.
I ran an Engle, Crane and the last was the best performing, was a H.O.T. Chevrolet cam with 1.6 (Crane) Roller Rockers. You don't need to change the springs but you will need to change the front plastic cover because you will probably break it. I am just getting ready to install a H.O.T cam in Bob's 350 so if you like I will take some pictures as I go.
Discussion Starter · #13 ·
Adrian, that would be great if you would take some pictures and email them to me with some tips to make my job easier or you can post them if anyone else is interested . My email address is [email protected]
Adrian,
I would like to see them, too, please.
Like Jack already said, please post them here, or send a copy
of Jack's email to [email protected]
Are you going to go with gear drive?? Everyone I've read about on their sites talk about having to make "minor alterations"....kinda wonder if it can be done with the motor in the scoot.
I was thinking if I pulled the motor to do the frame next winter it would be a good time to go to gear drive, chrome pan, front cover, etc......
Just my 2 cents
Mike speaks the truth about the lower end TQ----make the most of the power!! We do not have many gears to choose from!!
Cam replacement.
Yes the cam can be replaced with the engine still in the bike it just takes a little time and patience.
Discussion Starter · #20 ·
Tim , yes I read that about the alterations and because of that and the fact that the noise might drive me nuts , I am going to stick with the chain . I've heard cars with the gear set up and yes they do sound kinda wild but they are not setting on top of their engine like we are .
I've got to talk to Mike more about the cam he is running . I want the low end torque as long as that same cam will give me the lopeing sound that I love .
I've been wanting to do this cam change for quite a while , but with moving and all that it's been put on the back burner . Now that I'm settled and have my nice warm dream garage , it's time
1 - 20 of 35 Posts
