1 - 6 of 6 Posts
Okay here goes i need some imput.I'm building a custom V8 trike from a american V king frame with a 76 vette rear,forks from a wide glide. So here's the good part need some answers or help. What type dist? What front pully for gen,water crossover for pump and where can i get these? Also if anyone has any detailed pics or books,manuals anything i'll be glad to buy them. At 45 i got the V8 itch but with bad knees it's hard to keep up a 2 wheeler so i't got to be a trike. Even before i got my first truck i had a bike and after my first harley i built everything afterwards. If i can't builed it i won't ride it. So any help from anyone would be helpful.
dist
well was looking for the one in the V king or just what the others use too. It dosen't say on the V king site what dist they use and if they do i haven't found it. Okay i take it you have one,what kinda front pully do they use for the gen? I take it they use a plate between motor and bellhousing for a mount ,they make or buy? Any other help you can give would be helpful.
They don't use a distributor, the frame is too close to the rear of the block, they come with the Electromotive crank trigger ignition.
It uses a single pulley front hub with the crank trigger, without a harmonic balancer.
Front of block motor mounts, and a motor plate in the rear.
1 - 6 of 6 Posts
