1 - 20 of 27 Posts
To any and all mechanics out there! I went to Myrtle and had a great time, BUT I came home, cleaned the bike and checked the oil. That's when I found the bottom 4" of my dip stick is gone. :evil: How difficult is it to remove the oil pan and should this be where I find the piece?
Hi Rob, If it broke off in the engine, it will be laying in the bottom of the oil pan.
Pulling the pan is a big job.
If the dip stick is magnetic. I would first try draining the oil and fish around through the drain plug hole with a magnet. If that doen't work. Pull the distributer and do the same.
That would be the fastest and best way.
Rob,
Are you sure that you came home with YOUR dip stick?
You never know sometimes.
I would think you could probably just leave it in the pan. It can't go anywhere. The pickup has a screen on it, and if it is magnetic, it's stuck to something like the side of the pan. Just my thoughts.
I'm no expert about this kind of stuff. What do you guys think? Just leave it there until the day comes when you have a problem and the pan MUST come off.
Bryan
I would take Mikes advice and drop the oil.....get a long neck magnet and see if you can locate the piece. Not sure about the configuration of these pans (Geezer ?) but they most likely have windage trays in them which will keep you from having complete access to the pan......
Only problem I could envision is the engine at high rpm and the damned thing deciding to go "swimming". Ouch ! Don't think you can get the pan off without pulling the motor out.
A neighbor of mine a long time ago, had help building a motor for his stock car. After the motor assembly was complete his helper couldn't find the oil pan drain plug, so he just got another one. On initial start up the motor sounded awesome, instant throttle response, open headers singing away, then bang, the crankshaft found the missing drain plug that had been placed in the oil pan for safekeeping. Quite a nice size hole in the side of the block.
But what harm could a little piece of dipstick do :twisted:
I haven't looked, but you might be able to drop the pan in the bike enough to get a flex magnet in there and dig it out.
It would bug the sh*t outta me to have that in there and I'd have to rip it apart to make sure there's nothing there.
I just couldn't leave it in there either. The turbulence at speed might make it do crazy things like trashing your engine. Probably not but living with that possibility in your head would not be acceptable to me.
I'd start by removing the dipstick tube. Maybe it will be standing up and the broken edge will be reachable. If not, maybe a thin magnet down into the dipstick tube hole will do the trick...Just a thought and the way I'd go first...Joe
If it is magnetic try dragging a magnet tward the drain plug along the bottom outside the pan and it may at least put the ghost piece in a better location for extraction.
I'm with you, Joe. A couple of years ago I rebuild a Ford 460 BB from
ground up. The engine was back in my Lincoln and broken in, when I
decided to turn the vacuum pod in another direction just for "optic"
reasons. Cylinder#1 at TDC - then I pulled the new Mallory dist. I didn't
noticed that I pulled the oil pump drive as well, which shouldn't happen.
The oil pump drive was secured with a snap ring, which was somehow
slipping over the pump drive. At the point when the dist was 3/4 way out I
heard the snap ring fallen into the oil pan. DAMN! I fished one day without
success thru all openings. Then I thought about 2 days what to do now. All
my friend told me not to worry about it and they would leave it in. But I
couldn't live with that. I lifted the engine 10" up, and dropped the pan just
to get this damn small ring out. Probably it wouldn't have hurt anything if
I would have left it in, but who knows for sure???...
Discussion Starter · #11 ·
Thanks to all for your replies, I am no mechanic by any stretch and will try to fish around. If I can't find it, I too will never feel comfortable. I will let you know how I make out. :cry:
Rob, How in the hell can you break the bottom 4" of a dipstick off?? Ya think it was the burn out at Myrtle Beach :?: I hope ya get it solved. I couldn't...wouldn't..... want it in my pan. Remember, if all else fails, hire it done. A hammer and chisle won't work here. My best to you my friend. Later..Steve 8)
I second Mike's request. We're all waiting to hear about the broken dipstick Rob.........Where are you???? Steve
ROB>>>ROB>>>>ROB>>>>where are you???????????? Update please!
Anyone know of Rob's phone number. Its not like him to not respond to us. I hope everything is OK.........
Rob...Rob.....Rob....... are you there??????????
Steve
Discussion Starter · #19 ·
Sorry Guys, I have been working every day for the past couple of weeks. I have not had any luck with the dipstick but I also have not tried very hard yet. :oops: All I can do is to drain the oil and see what I find. I have been told dropping the oil pan is no small task. And for you Steve; if you didn't make me do that burn-out I may not be in this position! :p
If it were mine I would leave it alone if you can't get out of the drain hole.
1 - 20 of 27 Posts
