Two years ago I wanted to increase my nightime illumination and installed a 130 watt Xenon bulb. The heat "cooked" the reflective surface of the headlight and turned it a milky white. Is there a replacement light around which will take a higher output bulb without destroying it's reflective surface? I have a Headwinds shell and the standard 7" diameter. what is the highest wattage halogen bulb that can be used safely?
What are you light freaks doing?...Joe
