Anybody know anything about these guys?
1793 Views 7 Replies 5 Participants Last post by  V8GRUMPY
1 - 8 of 8 Posts
Looks like a nice package but you sure do have to get way up in the rpm to reach that power... the 350-450 hp would be usable I'd say, but after that I wonder who would, besides Crazy Rick!
NITROUS :lol: 8) :? :D :) :twisted: :capwin: :beer8: :cop2:
The safe & sane solution to 150 additional horses.........at the touch of a button and only then...........doesn't even change the power curve........add a high stall converter and grab yourself by the nuts just before you "touch the button"
Don B.......did you 'juice' yours yet??
No juice yet. :roll: Still not sure what I'm going to do with this bike yet. I hate it and love it at the same time. :roll:
When I was doing the research on who was going to do my engine I never ran across these guys nor did any of my racing buddies mention them. All of that being said when you do have your engine built and I have my thoughts on that but you need to decide if you are going to run the spray from the onset. Otherwise, your engine will not have the life or the reliability you are seeking. I have had several discussions with Scott Shafiroff on this subject who is one of the foremost authorities on running “the spray”. The engine currently in my BH was not built for the spray and it was made to run on 93 pump gas, the heads and cam were ground to make a long flat TQ curve so that as we have but 1 speed to realistically run hard in the power is always present. Just some thoughts and you really should call Scott and tell him what you are thinking about because he would love to build a small block for our bikes and “get the word” out so to speak. The components he uses are absolutely the best obtainable and if you go to his website and look at the shop it looks more like a hospital than a engine shop because it is so clean.
There is a huge performance difference in the ability to use the horsepower from an automobile engine vs. an engine built specifically for the demands of a motorcycle esp. one with only 1 speed for running it hard.
My .02 hope it helps.
:D
See less See more
Lamont,
Looks like they have been around for awhile and they use good stuff internally, even on the "package" motors.
Regarding NOS, the new systems are not like the 'old days' where the fuel system had to be richened up in order to run the NOS....all of the modern systems introduce additional fuel along with the NOS to avoid detonation.
On the new systems, you can hit the button below WOT and not do damage, because the system is adding fuel as well. Try it on empty tanks and you will see how fast it will flood the motor.
You do have to be sure that the engine components are capable of the additional hp. For instance, GM does not recommend that a ZZ4 bottom end be continually subjected to over 500hp.....so it would be foolish to put a 200hp shot in a ZZ4 and not expect a problem somewhere. So if you were going to build an engine from the ground up, just make sure that the rods, pistons, etc. will handle the advertised hp plus any NOS that might warm your blood later on.......or simply plug a NOS system on to your current motor....remember the grin you got from the converter???? Double that with a shoot of the 'juice'.
And it's cheap :lol:
See less See more
Tim,
Nope.....not yet. Trying to figure out where I could mount a controller. No good up by the risers cause I have the pullbacks on. I'm afraid all I'll do without a controller is smoke the tire. I don't really want to do that at the higher speeds. Although, it might be fun for ****s and giggles. I hope to talk to a few guys in Myrtle that have done it. Maybe I'll get some ideas.
Don,
The controller itself is not that large. I would bet you could fabricate a neat bracket and utilize a set of "P" clamps or other such items to mount it to the risers???
The controller is nice if you really want to go fast and save the tire.
1 - 8 of 8 Posts
