Kevin at Stamford Boss recently showed me his way of aligning the rear wheel which makes sense and works. He simply uses calipers to measure the distance between the front of the slider block and the front of the oblong hole in the swingarm on both sides and makes them the same using the adjuster bolts. Then adjusts the belt tension by turning both adjuster bolts equally on both sides. This is so simple and it works.
