1 - 3 of 3 Posts
I need to replace my alternator belt on my SB 2005 trike. I researched an older post to find that most of you said to get a Gates #7315 32 1/8. Is that the correct belt. Thanks in advance.
Stone
Stone
Hi Stone,
Read through the following thread and I think you will find what you need to know. Some good tips and part numbers. Hope this helps! In my case, I used the Dayco 15320 and found it easiest to take off the alternator pulley first as I was working alone.
http://www.mybikeforums.com/forums/showthread.php?t=19628
Tim :tour:
yes on the 385hp part numbers for my 2000 SB. some of the available belts have inside cogs, some have outside cogs and some are smooth inside and out. i believe they will all work. i must remove alt pulley to install. any longer belt will not tighten enough. full slack hits oil pan and full tight hits frame with only ABOUT 1 inch in between. i have the factory v pulleys and for some reason have been losing alt belts recently with no apparent changes otherwise. i am having the squealing and may address later after resolving another more immediate issue.
1 - 3 of 3 Posts
