1998 volt meter
Results 1 to 2 of 2
Thread: 1998 volt meter
  1. #1
    Senior Member
    Join Date
    Jul 2013
    Location
    blytheville arkansas
    Posts
    123
    Default 1998 volt meter
    at what volt does your volt meter run when you are on a ride I plug my boss hoss in on a bat. box at home I start out at 14 volt but after a little bit I see I run 13 volt bike had not fail to start yet but it act like it might not at time should it be 14 or is 13 ok I know we got big motor with lot of comp just need to know new owner and still feeling it all out
  2. Remove Advertisements
    V8BikeRiders.com
    Advertisements
  3. #2
    Veteran Member V8GRUMPY's Avatar
    Join Date
    Dec 2003
    Location
    Waite Park, MN
    Posts
    4,836
    Default
    Larry the volt meters are subject to odd things - easy thing to check - take off your seat, hook up a digital voltmeter to the battery terminals - at high idle (1500 or so) it should show the alternator putting out 13.8 to 14.3. If it is, then you maight have a poor ground on the gauge or somewhere
Posting Permissions
  • You may not post replies
  • You may not edit your posts
